Remove FreeFileSync on macOS
eunos
How do you uninstall the application from macOS (it doesn't show any icons in the applications folder)
https://support.apple.com/en-us/102610
You can also do a search for FFS to find where it is stored if it isn't showing up in 'Applications' for some reason. Some programs, like Malwarebytes, have to be uninstalled by opening the program and clicking the "Help" bar at the top. Maybe FFS is the same, check that also
