connection attempt more than 15sec.?
Kanizzl
I have the problem that the attempt to establish a connection always stops after 15 seconds if the server doesn't connect via SFTP in that time. If I try it a second or third time, it will work at some point. I think it might be due to the ping times and the access control of the NAS I want to synchronize with?! Is it possible to increase the time it takes to try to establish a connection to 20 or 30 seconds? I think that would solve the problem.
Thanks!
viewtopic.php?t=7350&hilit=timeout#p36817
FFS already has configurable timeouts
Kanizzl
Unfortunately there is no solution to the problem here!
The same options is present for the other tabs as well
