Verify a copied file
blazeguru
Ok, maybe I am a little paranoid, but I was looking for a verify option to verify and be sure that a file is correctly copied. I found in another discussion that there is a 'VerifyCopiedFiles' option in
GlobalSettings.xml. Is it correct that with this option set to 'true', FFS will compare the copied file and the original file ?
Are there more great features like this and are they documented somewhere ? Or do I just have to look in GlobalSettings.xml (options are self explaining?)?
Great program. I'm discovering more nice features.
Yes, it will read source and target files again after copying and binary-compare them.
This depends on what is a great feature for you. The settings in GlobalSettings.xml that are not shown on GUI are already set to good default values. Except for special scenarios there is usually no reason to change them.
