No Pause on comparing 2 folders??
miogpsrocks
Hello.
I am comparing 2 folders with over 7TB each, taking over 24 hours.
Why can't I pause this process like I do with the file transfers?
Can the developers put a pause ability on the file compare process?
miogpsrocks
I would be fine with a Pause that lets it finish comparing the existing file since it sounds like pausing midway is a difficult process. So maybe a "Pause at first chance" so maybe you can wait 10 seconds for the current file compare to complete then pause right after that finishes. The pause does not have to be instant.
Again, I had over a 24 hour waiting period to compare a over 7TB folder. Any type of pause even if not instant would have been greatly welcomed.
therube
