FFS makes explorer.exe to crash
Rom83
Since today, when opening FFS, I can no longer click inside it on any entry of the GUI, it freezes and makes the G.U.I to crash entirely (explorer.exe).
Does anyone else have this problem ?
No issues here. Reboot your PC. Open CMD as administrator and run these three commands:
1. sfc /scannow
2. dism /online /cleanup-image /restorehealth
3. sfc /scannow
Yes, run sfc twice. If all that doesn't work, perform an in-place upgrade/repair of Windows by downloading the media creation tool from Microsoft. Make sure to select 'keep apps and data' when you 'upgrade'
therube
> when opening FFS
Version?
OS?
Does the same happen if you were to restart your computer into Safe Mode?
