Please S3 liked way to sync
I always use the S3 like server for my markdown sync, I wonder the a new way to sync my programming code
Can you please clarify your question?
Are you wondering about FFS support for S3 cloud servers?
If so, you would need to use special software designed to mount folders and map drives to S3 servers. There are both free/paid options.
Then, you can use FFS.
I just used the Obsidian Plugin Remotely Sync for my note, it supported the s3 service that enable me to sync easier. So I just hope the FFS support the original S3 serviceCan you please clarify your question?
Then, you can use FFS. Flowers4, 15 Nov 2023, 02:48
FFS knows nothing about s3 storage.
You likely need to mount the s3 storage using an open source cloud mounting program.
