I have FFS 13.1 64-bit donation edition. I have 2 real time sync jobs: bridge & info, which, I think, have identical options set. The bridge one works perfectly, i.e. if I open a file & make no changes & close it, there's no pop up or sound.
If I open a file in the Info folder, wait 10 seconds, the FFS dialog box pops up & makes a sound. It just started doing this recently & it's annoying. I only want the pop up if there's actually a change.
How can I change this behavior in my Info folder.
Thank you in advance.
FFS dialog box pops up with a sound every time I open a file
Sorry. I just solved it. I resaved the Info job as a batch file (clicking the icon in the top right of FFS) & checkmarked "run minimized" & "autoclose". Now it's behaving.
