Good night
I really like the resource to shutdown computer after backup finhesed.
But, sometimes I needed to cancel the shutdown, and there is no way.
I would like to have this option.
Thank you
New feature-Abort shutdown
You could:
- Create a second sync that doesn't shut down
- Change the setting prior to running the sync
- Cancel the sync before it finishes
- Change the post-sync command to wait a longer amount of time before shutting down, then use "shutdown -a" to abort the shutdown
