file upload in Digi Storage with data when is uploaded
milanezu
Hallow!
When I did the first synchronization with Digi Storage, the date of the files in Digi Storage was marked with the date when the synchronization was done. Now, when he compares by date and size, FreeFileSync see the different date and ask to upload again.
How do I remedy the situation?
How do I keep the correct file date, not the upload date?
I use V 13.1, 64 bit, by 23.10.2023
I try V 12.5 but same effect. I see in topic viewtopic.php?t=10781. It did not work.
Thank you in advance!
Sounds like the location doesn't support maintaining timestamps. Try copying the files over manually. If the timestamps aren't maintained during a manual copy, then can't use timestamps for comparison
