Hello all,
Is there a way to select a parent folder and all subfolders and files contained therein via the parent folder, in the synchronization preview?
So far I have only been able to do this by manually selecting all subfolders and files in a parent folder via shift-click?
Select entire folder tree more easily?
Once you run a compare, you can use the "Overview" panel in the bottom-left to do this easily
