Transfer from old to new computer
klt
Is there a way to copy all my configurations and setups onto my new computer?
When you saved the configurations, you chose where they were saved. Copy those to the new computer and open them in FFS
And for your setup(s), copy your old GlobalSettings.xml -file(s) to the correct location(s) on your new computer.
Note that each FFS-user on your old computer (if more than one) has its own GlobalSettings.xml -file.
