`Synchronization Settings`> [`Filter`>`Exclude`] vs "sync.ffs_db" & "sync.ffs_lock" files (!?)
PauloCastro
Hi! I have a
Question/Doubt:
Taking into account that these files ("sync.ffs_db" & "sync.ffs_lock" files), created in the Source/Destination folders, and which contain information about the synchronization process, carried out at a given time, shouldn't they be excluded, by default, in [`Filter`>`Exclude`] in the `Synchronization Settings`?
__________________
Thanks for the clarification
PCO
They are hard-coded in the software to be excluded
PauloCastro
They are hard-coded in the software to be excluded xCSxXenon, 28 Nov 2023, 18:47
Many thanks @xCSxXenon ;)
This situation was causing me some confusion and, therefore, I was putting these files in `Exclude`!... ahahah :))
It makes perfect sense to be as you say!
Thank you very much for your answer
