Left and right panes do not match
When I click "compare" to check latest and early backup versions of a folder, unchanged files appear on both sides but on different lines (for example, xxxfile appears on line 4 on left, but line 5 on right). As a result, it says xxxfile (line 4) only exists on the left-drive, and line 6 (identical) version only exists on right-drive. Thus, with a large folder, synchronisation takes a very long time, for no reason. Why is this?
Your left/right locations are not set correctly
How do I fix this? I have uninstalled and reinstalled the program
You choose the locations yourself, it is not an issue with the program, it is an issue with how you set it up
