Good evening,
I use FreeFileSync Version 13.2.
When I synchronize files I get this warning "Server does not support the MFMT command"
my FTP server is the one in IIS.
Do you know how I can solve the problem? is it possible to enable MFMT on Windows?
FTP error because doesn't support MFMT
viewtopic.php?t=5567
"After researching this issue, it appears no versions support FTP server command extension MFMT, as of the date of this answer."
From: https://serverfault.com/questions/617253/iis-ftp-server-command-mfmt-what-versions-if-any-support-it
