RealTimeSync: Symbolic Links
Joern
Hello!
At first, I'd like to say a big thank you for this great software! Really useful.
Now my problem:
I'd like to use realtime-sync and it basically works. But if there are symbolic-links-folders (deeper) inside the watch-folder, it seems that filesync doesn't get a change-signal if something changes inside the symbolic-linked folder or deeper folders/files inside it. when I restart the batch-script, it syncs perfectly.
Is this an issue of the operatingsystem? I'm on Windows 11 64bit.
Many thanks in advance,
Jörn
Yes, this is going to be because the change isn't properly being reported to RTS. I am not sure if a symbolic link behaves any different than a hard link, but I would guess a hard link would have a better shot of working the way you describe
Joern
Hey, thanks for the quick reply,
What is RTS? So i guess you can't do anything about this, correct? I'll try hard links then.
Ahoi!
Jörn
RTS = RealTimeSync
