Can Microsoft OneDrive be used or added?
zonemaster60
I only use OneDrive for my cloud storage. Is it possible to sync with my online account?
SMDAZ
In the same boat! Will this app be updated to use MS OneDrive?
Flowers4
If you are using Windows 10/11 with Onedrive from Microsoft, you have a folder mounted to your Onedrive.
This is how to access Onedrive with FFS. You should be able to navigate to your OneDrive folders from within the software.
You can "Map a Drive letter" using webdav if you like also.
And, there are 3rd party programs that mount cloud accounts too.
Microsoft only allows you to access ONE personal OneDrive account per computer so if you're looking to back up an account other than the one that is being used on the machine with free file sync then you will need a third party app for that.
