Cannot create directory: Error Code 3
klau01
Getting "Windows Error Code 3: The system cannot find the path specified" while running synchronization without the folder created before hand, which FFS is supposed to create the folder automatically.
I believe the problem lies here.
Info: Synchronizing folder pair:
Left: 'X:\'
Right: 'F:\XXXXX\'
Error: Cannot create directory 'F:'.
A bug?
Probably not a bug in FFS, but a problem with the buffering on your storage medium. Please always post *full* error messages, else you are leaving out vital information. Additionally check what the status of existing directories is on the target volume.
daniel-lo
I have error 3 Problems in Batch mode. While the same settings work fine in FFS itself. My version is current. Pls. also see here:
viewtopic.php?t=1114
