I want to backup my Dropbox folder locally. I want to exclude the .dropbox.cache folder from the backup.
I added this line to the filter:
\.dropbox.cache\
However, the "marker_file" in the dropbox.cache folder is still included.
How is this possible?
Exclude .dropbox.cache directory from backup
Assuming your Exclude Filter rule is setup and working correctly,
said "marker_file" likely already pre-existed in your backup location.
Excluding a file (or a folder that a file is in) from your sync will make
FFS ignore that file; it will not make FFS delete any such file
from your backup location.
Thanks for your reaction.
I checked my backup and the folder .dropbox.cache was indeed on my backup drive. I deleted the folder and did a new comparison. FFS still wanted to move the .dropbox.cache folder to the backup drive.
I don't know why.
Here are the details:
Exclusion filter:
\System Volume Information\
\$Recycle.Bin\
\RECYCLE?\
\Recovery\
*\thumbs.db
\.dropbox.cache\
Screenshot:
I don't know why.
Exclusion filter:
\$Recycle.Bin\
\RECYCLE?\
\Recovery\
*\thumbs.db
\.dropbox.cache\
Screenshot:
In- and Exclusion Filter rules are relative to the root of your base-locations.
Because your base-locations are D:\ and E:\Backup (and not D:\Dropbox and E:\Backup\Dropbox), you need to exclude
\Dropbox\.dropbox.cache\
Your present exclude rule
\.dropbox.cache\
would exclude the folder .dropbox.cache if that would exist in the root of D:\ or E:\Backup .
\.dropbox.cache\
