Move Than Copy
Is there a way or action to move a file from the source to destination rather than just copy the file to the destination. If a file was initially copied from the source to the destination, resulting in a duplicate file in the destination folder, you could use FreeFileSync to delete the duplicate file from the source. This action essentially achieves the same result as moving the file from the source to the destination.
Not an automatic one:
viewtopic.php?t=10850#p41436
viewtopic.php?t=7690
But it seems you already discovered the manual way to do it.
