I've been using FreeFileSync without any problems until now.
Unfortunately, now I have a problem. During a backup, a tmp file was created and it's causing a problem. The USB flash drive is no longer correctly recognized and I can't delete the file. I get an error 0x80070570.
Can you help me solve the problem, as my USB stick is becoming unusable?
BR,
Error 0x80070570 with 'ffs_tmp' file
English translation of the error?
It was impossible to delete this file as long as the USB key was in the right-hand port. I don't know why, but when I placed the key in the USB port on the left, I was able to delete the file. Why was this? I don't know why.
I also had a problem with the USB key appearing twice in Windows Explorer. I was able to change this via REGEDIT: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\DelegateFolders.
Now everything seems to be working properly. The key is read, I can modify it... I can use FreeFileSync...
Oh yes, finally, I used SupportAssist (https://www.dell.com/en-us/lp/support-assist-for-pcs) to update various elements of the Dell PC.
Thanks for your ideas and happy new year to all.
BR,
BR,
