Compatible with Backup made with Win10?
Onlyonequestionlol
Hello!
Im currently Backing up my Files with the inbuilt Windows 10 "Backup and Restore" tool from HDD1 to HDD2.
Windows creates some kind of Backup folder named after my Machine.
Now im wondering if "FFS" is Compatible with the Backup made with the Win10 tool?
So if i run it will it only Add new or changed files to the existing Backup?
If the anwser is No ill abort the Backup process now and Install "FFS" first.
The process takes alot of Time (16TB) which is why im asking beforehand.. :)
Thanks for your replys!
No, you don't want to mess with the backups that Windows creates. They use extra stuff to create a sort of 'timeline' when restoring from, it doesn't just copy the files to a destination.
