I am trying to get real time sync to work. When it runs it shuts down the computer.
What have I done wrong?
Real Time shutting down computer
What command is in the "Command line to run..." box?
Is there a "post-sync" command entered in the configuration of the .ffs_batch file you are running from RTS?
On the Synchronization Settings screen, bottom right, in the last box, there are two dropdown boxes:
The first - Run a command: Defaulting to "On completion:"
The second - Defaulting to "Example: shutdown /s/t/60" (no other choices in the dropdown there)
Is that the area you are referring to?
This ffs_batch runs fine in Free File Sync. But when I run it in Real Time Sync it shuts down the computer.
Sorry, I don't see a way to include a screen shot of the Synchronization Settings screen.
I think I found the problem.
On the save as batch job screen, the "When finished:" dropdown has defaulted to: "System: Shut down".
I cleared this drop down and resaved the .ffs. file and Real Time is now running with out shutting down the computer. So I guess the problem was with the "Save as" defaults.
