Hi ! Sorry if this topic was already discussed... I tried to find it without success
My setup is a batch that runs daily mirror syncs with the Google Drive FFS's feature (by the way, Is it the most efficient way to do this ?)
I noticed that when a folder (containing other folders and files) is deleted in the source, FFS removes only the files in it... keeping all the path folders empty in the target location.
Am using the same settings to sync with a hard drive and the folders are successfully deleted.
Is there something am missing here ?
Thank you for your help :)
FFS mirror sync not deleting removed folders from Google Drive
UP ?
Anyone who can help me solving this issue ?
Doesn't seem like it
Hi ! are you facing the same issue ?Doesn't seem like it xCSxXenon, 19 Jan 2024, 15:10
