how do I setup FFS so that it deletes the file instead of using the recycly bin.
PdPiCkLOSEpTIot
So I was synching (mirror option) and I notice that it created a "recycle bin" folder on the destination folder.
Is it possible that FFS skip the creation of this "recycle bin" folder? if yes, how?
thanks
You can select whether to delete to Recycle Bin or permanently in the configuration settings.
The may not prevent the folder from existing though, as Windows may create that for other reasons
Because you write that the "recycle bin" folder was created on (in?) the destination folder, this reads like it happened on a (Synology?) NAS.
If that is the case, the creation of said folder and moving any deleted files to that recycle bin folder, may even be completely unrelated to FFS, but just the result of a NAS setting.
