Completion Flag on Syncs
bluera1028
I used to see a green check mark next to each sync task on your home screen when a sync completed successfully. A few updates ago this green check mark disappeared. I have multiple syncs I run manually, and it is hard to keep track of the syncs when that flag is gone. Also do you have any intentions of automating the syncs to run on a schedule.
Right-click on a column header above your list of saved configurations, click default, or re-enable the 'Log' column
