.ffs files causing errors
Have been looking for a MS synctoy replacement. FreeFileSync is much better. However, am getting errors from .ffs files. How to fix?
The user under which credentials this instance of FreeFileSync (FFS) is running does not seem to have write-access to
\\NAS-BACK and/or \\NAS-BACK\{Archive}Pictures.
This may e.g. happen when running FFS via the Task Scheduler. By default those tasks are run as the SYSTEM user, which most times does not have write-access to network resources.
You can change your Scheduled Task to run under specified user credentials.
