Erro in version 5.20 of FreeFileSync
paulofmarques
I'm using version 5.20 of FreeFileSync and synchronization is completing with errors, but does not syncOpens the log with the following message to multiple files:Unable to establish the privilege "SeSecurityPrivilege".Error Code 1300: Not all privileges or groups referenced are assigned to the caller. (AdjustTokenPrivileges)Error Synchronization completed with errorsWhat should I do to correct this error and sync?Tks
Adm. Paulo F. Marques
petrovski80
Run FFS as administrator or disable its features that require elevated privileges (in global settings).
