It should be great to have a check box to disable paths in a job definition with multiple folder pairs.
Some sync batchs are really long to proceed and sometime we got sync errors in just one folder pair. If we had a check box to disable some paths to sync only some folder pair and ignore the other ones we could save a lot of time.
Thank you!
Check box to disable some folder pairs in a job definition
Thank you
