Log file in .txt format
milter77
Hi there!
Is there any way to save log file after the sync is complete?
petrovski80
FFS saves a logfile by default. It's located here: %AppData%\Roaming\FreeFileSync\LastSyncs.log. If you want session based log files, just save the sync job as a batch file and execute. This is also described in the Help: FreeFileSync > Schedule a batch job.
milter77
Thanks a lot!
milter77
Thanks a lot!
