Feature Request - Versioning: Delete files older than X
varns
It would be great if you can add some functionality to be able to delete versioning files automatically. Maybe a setting that allows you to delete versioning files or folders older than x days/weeks/months?
Thanks for considering.
Varns
There is already the option of keeping as many versions as you select for as long as you select.
For a detailed description see here.
As obsolete versions (as per your settings) will be (automatically) deleted by FreeFileSync (FFS), not directly by the OS, obviously such deletion will only occur the next time the FFS sync configuration is run.
