Update vs. Custom sync, new vs. existing GUI
therube
Update vs. Custom sync, new vs. pre-existing .GUI ... just noting... an oddity...
If you have an existing sync (LastRun.ffs_gui), & it is an Update sync, with the 'Use database' option selected, if you then deselect the 'Use database', & OK that, it then shows as a Custom sync.
Just odd.
(Don't know offhand if there is any meaningful difference due to that change?)
Any changes from a default configuration setup will change it to a custom config typically, but not the toggling of the db files. I wasn't able to replicated that behavior though and it kept the sync type the same
