Transfer home folder
eddacker_ffs
Just started using FFS and did a test sync. Used a 5GB folder "home" that had both files and folders. All the contents of the folder were synced quickly. But their folder name "home" was not. Help me understand; I am expecting the 'synced' folder to be copied and its contents.
TIA
That is not what FreeFileSync (FFS) does.
FFS syncs (just) the content of the left and right base-location.
So, you need to sync between e.g.
C:\XYZ\home => D:\ABC\EFG\home
and NOT between
You can enter/type D:\ABC\EFG\home as your right location even if home does not exist yet in D:\ABC\EFG\; FFS will notify you that that home folder does not exist yet and happily create it for you.
eddacker_ffs
Very clean explanation, appreciat_edd
Almost six months later, almost impressed lol
