When running FreefileSync in foreground (gui) logs .txt are created in my own specified option folder. Using corresponding ffs_batch logs are created in default Appadata\Roaming .html folder.
I just upgrade Freefilesync to 13.3.
Any Idea, options are still correctly set.
No way to create log in my own folder
It seems you are running your ffs_batch file from the Task Scheduler.
By default, the Task Scheduler runs tasks as the SYSTEM user.
In the Task Scheduler you can modify the ffs_batch file scheduled task to run under specific user credentials
