I'm learning FFS and did my first sync
To: E:\Coal Mine History Project
task completed and directory checks ok on size and files except E had 6 more files than D. I'll check that soon
I ran FFS again with same locations to check file count since being different, but when running "compare" no files were shown in both windows.
What am I doing wrong?
Files not visible after sync
Probably nothing.
(By default, or always, not sure particularly, but in any case) "equal" files are not shown - but can be.
Bottom statusbar, click the '=' icon.
