Copy files from subfolders to one only destination folder
fablepd
Hello . In order to upload files from subdirectory to Google Photos I need to copy image files from subfolder to one only destination folder , i.e without replicating subfolder structure. Is there a way to do that ?
Thank you !
There are ways to do this, but not easily. FFS is a sync utility and your scenario is really no longer a sync process. You can set each subfolder as a source and point them all to the same destination using the "update" sync method. But this will be very cumbersome for more than a few folders.
viewtopic.php?t=10499
viewtopic.php?t=9662
viewtopic.php?t=8370
