Is there a specific folder that these two files need to be extracted to? Iam trying to extract them into C:\Program Files\FreeFileSync\ but for both files it says cannot open output file : Access is denied. Any assistance would be most appreciated. Thanks. Brad.
trouble installing the setup.exe & setup.key
Normally (normal) users don't have write access to system folders like \Program Files\.
Simply extract all content of the FFS installer ZIP-file to a single folder where you have write access, and install from there.
Don't extract to the Program files folder, that it not how you install programs onto a computer. You extract/unzip the compressed folder you download, then run the exe inside the extracted folder. When you unzip it, just set the location to be where the original zip is
