FFS Stopping
Recently, FFS stops very soon after starting a sync session. Any ideas? Thanks
What does the log-file tell you?
It says "nothing to synchronize" when there have been many changes on the disk being backed up. I ran a Compare then an Update and it correctly did the backup
Then it would appear that is the case.It says "nothing to synchronize"
Explain your sync settings & what you are doing.
