Error log files from FreeFileSync
Eldhose.raju
Hello Team,
I am getting huge log files with below content. Could you please advise what exactly is this.
Cannot read directory My\File\Path\RecycleBin~001a.ffs_tmp\RecycleBin~dcf0.ffs_tmp\RecycleBin~f994.ffs_tmp\RecycleBin~f94f.ffs_tmp\RecycleBin~e8ef.ffs_tmp\RecycleBin~ec25.ffs_tmp\RecycleBin~baf0.ffs_tmp\RecycleBin~357c.ffs_tmp\RecycleBin~2b94.ffs_tmp\RecycleBin~c036.ffs_tmp\RecycleBin~fcea.ffs_tmp\RecycleBin~3bfc.ffs_tmp\RecycleBin~a3c5.ffs_tmp\RecycleBin~186b.ffs_tmp\RecycleBin~d05c.ffs_tmp\RecycleBin~72a4.ffs_tmp\RecycleBin~0322.ffs_tmp\RecycleBin~cd58.ffs_tmp\RecycleBin~3044.ffs_tmp\RecycleBin~aa7c.ffs_tmp\RecycleBin~dd78.ffs_tmp\RecycleBin~8cc1.ffs_tmp\RecycleBin~8344.ffs_tmp\RecycleBin~e729.ffs_tmp\RecycleBin~d1cd.ffs_tmp\RecycleBin~ad65.ffs_tmp\RecycleBin~a607.ffs_tmp\RecycleBin~0fbc.ffs_tmp\RecycleBin~4906.ffs_tmp\RecycleBin~1308.ffs_tmp\RecycleBin~d07f.ffs_tmp\RecycleBin~210d.ffs_tmp\RecycleBin~51fc.ffs_tmp\RecycleBin~85d0.ffs_tmp\RecycleBin~b9e4.ffs_tmp\RecycleBin~abb2.ffs_tmp\RecycleBin~bb3f.ffs_tmp\RecycleBin~58b9.ffs_tmp\RecycleBin~34e9.ffs_tmp\RecycleBin~10f1.ffs_tmp\RecycleBin~974f.ffs_tmp\RecycleBin~9d16.ffs_tmp\RecycleBin~44c6.ffs_tmp\RecycleBin~fc52.ffs_tmp\RecycleBin~4aa9.ffs_tmp\RecycleBin~8909.ffs_tmp\RecycleBin~21cc.ffs_tmp\RecycleBin~ad3c.ffs_tmp\RecycleBin~a6e6.ffs_tmp\RecycleBin~df20.ffs_tmp\RecycleBin~606e.ffs_tmp\RecycleBin~2100.ffs_tmp\RecycleBin~d3e6.ffs_tmp\JobFolder.fcpbundle\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.fcpcache\.lock-dir.
Endless recursion
Which FreeFileSync version have you been using that created these folders?
Eldhose.raju
Hi Zenju,
Thanks for the response. I have version 11.2, 64 Bit.
Regards
Eldhose
Updating to the latest version will fix the issue. However the "My\File\Path\RecycleBin~001a.ffs_tmp" folder will have to be cleaned up manually.
Eldhose.raju
Hi Zenju,
Sure , I will update the application.
Also, would be there any data loss that can happen if we delete the Recycle Bin folder?
is it a folder that will be created by FreeFileSync?
Regards
Eldhose Raju
