Bit of background, I set up freefilesync to Update the Users folder from the C drive to it's backup on the D drive. When it runs it leaves a bunch of files in the recycle bin that look like they came out of appdata, it's mostly data files and tiny images, nothing a human would ever care about. I'd like it to stop doing this if possible.
I thought I set it to ignore appdata by adding \appdata\ to the filters. It looks like this wasn't enough, what am I doing wrong?
Also, this is for a paranoid old woman who will keep calling me back until stuff stops mysteriously appearing in her recycle bin, thanks!
Filtering out appdata and dumping stuff in the recycle bin?
Switch the exclusion to '*\AppData\"
or "\Users\%username%\AppData\"
Your current setting is excluding "\Users\Appdata\" which doesn't exist
I thought I was missing something like that, thank you! There are actually two users on the system, "*\AppData\" should catch both of them, correct?
Yes, use the star version since a '*' is a wildcard that matches anything
