Moving donation license to a new pc
DeirdreYoung
I'm going to replace a pc that has one of my donation licenses.
Should I just uninstall from the old pc and install to the new, or is there something else I need to do?
Deirdre
For donation edition, you may not even need to uninstall it. You will probably be fine just installing it on the new computer
DeirdreYoung
Well no. I get three installs.
John1234
Deirdre DeirdreYoung, 04 Mar 2024, 18:43
There is nothing that you must do. However, if you go to the web link that you have to download the donation edition there is a button that allows you to list the machines that you have the software installed on and there is an option to remove machines that you no longer use.
DeirdreYoung
Got it. Thank you very much.
Well no. I get three installs. DeirdreYoung, 04 Mar 2024, 20:03
Maybe there is a lack of consistency but I have it installed on six devices without issues, and others are only reporting a warning once they get to 10 installs...
DeirdreYoung
Hm. I seem to remember a maximum of 3 installs. Maybe that changed?
Softalk
Oops I just wasted one of my installs testing the installer worked.
John1234
@softalk
See my post above. There is a simple way to remove Test install from your list of active machines.
Softalk
@softalk
See my post above. There is a simple way to remove Test install from your list of active machines. John1234, 15 Jul 2025, 19:23
Thanks.. just seen that.
