Can you add a note to the plan? Can you mark a special file?
dublove
Because the location is limited, there are many schemes, and the settings and operation methods of each solution are not necessarily the same.
After a long time, I will forget, so I want to have a note to explain.
For example, a certain scheme contains many files, but I only need to operate for 2 files.
At this time, there is actually another suggestion, can it be marked with different colors for these two files?
Your request isn't very clear. You can 'tag' configs in the top-left panel by color and you can also add notes to a configuration in its respective settings windows. Is this what you are wanting/referring to?
dublove
Make a description for each solution
This forum is not your servant ...
