I would like you to add the possibility of monitoring files with the RealTimeSync software. Currently, the application only supports folders.
Thank you.
File monitoring with RealTimeSync
All files exist in a folder so what is the issue that you have run into?
Hi
I haven't encountered any problems, but I would like to have the option of adding files only in RealTimeSync. If I add the folder containing a particular target file, then all the other (non-target) files will also be monitored.
Depending on your situation, the Filtering, Include/Exclude settings might help?
This doesn't change what RTS monitors. What OP wants to do isn't possible without having that file in its own directoryDepending on your situation, the Filtering, Include/Exclude settings might help? therube, 16 Apr 2024, 15:00
