v5.11 appears to still have the high CPU / slow file transfer bug
vbjhfdbdj
I am using FFS v5.11 to transfer 500GB (150,000 files) between two external USB 2.0 hard drives.
The transfer starts off fine in the 8-15 MB/s range then over the period of an hour or two CPU rises to 50% on my i7 and bandwidth drops to a crawl of a few bytes/s.
I have uninstalled the old version and have installed v5.11 ... turned off everything ... virus scanners, etc ... restarted many times ... and still it ends up crawling.
Any suggestions ?
Cheers,
Mike.
vbjhfdbdj
Some more information ....
Using compare file time and size the system works normal.
Using compare file contents also causes the very slow / high CPU bug.
I am using Mirror Sync which causes the bug (I have not tried other types of syncing).
Everything else is at the default settings.
Cheers,
Mike.
The bug as reported here
viewtopic.php?t=1097
is definitively solved. So what you are seeing must have some other explanation. I assume you are on a dual-core CPU and FFS is consuming 100% of one of the cores? Does this problem also occur on any of the older FFS versions, except for v5.10?
vbjhfdbdj
Crap !
I just rechecked the version (it was v5.10) ... I must have reinstalled the wrong one.
I have installed v5.11 now and it is working fine for the last 2 hours.
My mistake ... FFS is an excellent piece of software ...
Feel free to delete this whole thread if you can.
Cheers,
Mike.
