Multiple windows opened
I noticed that I have so many windows opened with your Sync Saying Completed Successfully Not sure how to prevent this from happening I did click Auto Close on the one that I saw but the rest I have no way of stopping All I have is the Close Option . Please Help
Sounds like you are using RTS to automate syncing?
If so, go re-save your .ffs_batch configurations and make sure to check 'auto-close' and probably 'run minimized'
Where do I do that please
Found it Thank you
