Organize the Configuration tab
rustyhaight
I really like FreeFileSync and use it a lot but have one problem I can't seem to find a solution for. Maybe I don't know what phrase to search for here in the Forum.
Recently, I reorganized my Configuration tab with the various synch strategies I use between my desktop, portable drive I use traveling, as well as periodic backups. I currently have them grouped by the type of activity using colors and that works pretty well, BUT I would like the DISPLAY to change.
You can probably see my groups are showing in this order:
BAcKups,
OUTbound to my "Y" drive,
OUTbound to my "Z" drive,
LOCAL backups, and then,
INbound or restore from my "Z" drive to my desktop drives.
I suppose it is my "OCD" but I would like to organize them like this:
BAcKups,
I found I can remove the color highlight, add a number to the front of the configuration names and then recolor them but there has to be an easier way to reorder the Configuration tab. The order I would like reflects how I use them. I HAVE made the mistake of syncing the wrong direction which is one reason I was careful to group them as I have.
Open to suggestions...
You could select the first entry of each group, press F2, and prefix with a number.
byman64@gmail.com
I am not able to help your but I am searching how group the configurations.
I would like a tree group like standard folders tree
