Hi.
I'm on Linux (pop_OS 22.04 LTS) and I'm looking to connect and sync with my WD NAS.
IP is: 192.168.1.98
login: simon
share: /WORKFLOW/documents
I'm having a hard time in connecting, would like to know if the syntax is correct:
ftp://simon@192.168.1.98/workflow/documents
TNX
(FTP on WD is active)
Help on FTP syntax / Linux
You should only have the hostname/IP entered for the server location and then you select a directory to 'mount' from below
The syntax looks OK, including the share/path part.
However, I don't know if a WD NAS is case-sensitive; I know Linux is.
So, perhaps your problem is in /workflow/ versus /WORKFLOW/
