keep date
Is there an option to tell FreeFileSync to keep the datestamp of the folder when it is copied to the destination? Multi-commander does support this while Explorer does not.
No
@xCSxXenon; Thanks.
I'll have to use Multi-commander then and search for duplicate files afterwards.
