Where is RealtimeSync for mac OSX??
grahamjtr
I've started using FFS at work, and it seems to do all I require, and it works well so far. But I cannot find the RealtimeSync app which supposedly comes with it. Is this not supported by the OSX version? There is nothing else in the downloaded folder. I really need to be able to schedule backups instead of doing it manually, otherwise I will have to go to other software.
Any help would be great!
grahamjtr
Any news on this problem???
This really needs to be addressed...
smarz
Hi, I'm new with OSX (I'm using FFS in Windows since a long time).
To solve your problem it's probably enough to use OSX Automator and FFS batch.
I hope this can help you.
A first version of RealtimeSync for OS X can be found here:
viewtopic.php?t=708
