Try uninstalling and reinstalling
Error starting "/home/jack/FreeFileSync/Bin/FreeFileSync_x86_64"
Killed by signal 6
Can you please Help was working yesterday.
Jack Martin
FreeFileSync stop working Killed by signal 6
Try that still the same
Jack
Jack
Same problem here. Working fine and just stopped with this error.
I have tried to install some older versions, do the update again, check linux permissions, run tests with smaller folders and still not working. I'm using zorin OS 17.02, 32GB of RAM, Ryzen 5600 and a lot of free space on SSDs.
Does Anyone have a solution for that Killed by signal 6?
I really love Free File Sync, best solution ever (free, secure and fast)!!! but it needs to start working again
When?
While the program is running, or on initial start?
@Jacknz, what OS?
Maybe a memory allocation error?
Maybe OS is looking for specifically defined (sufficient) RAM space, & FFS is being more lax, & so tries writing outside that defined area?
When?
@Jacknz, what OS?
software closes while scanning
Zorin Os 17, Ubuntu based system.
32GB of availabe RAM, seens to be working fine.
MAybe a linux update broke something, but I don“t know that, other stuff working fine.
