I'm not sure when this started but v5.11 portable install is storing
GlobalSettings.xml
LastRun.ffs_gui
LastSyncs.log
in
C:\Documents and Settings\UserName\Application Data\FreeFileSync
rather than the install directory which defeats the purpose.
WinXP if it matters
Wm
Portable version storing files in Documents and Settings
The internal handling is quite simple: If FFS finds "uninstall.exe" it assumes local installation, portable otherwise.
Problem solved. I must have forgotten to press the Portable button in some previous install. Thank you very much for the quick reply.
